Home General
agiakosagiakos Posts: 15 Apprentice
Hello all,
I would like to ask if it is possible to increase the torque linearly according to how much the robot tool flange rotates. To give an example, torque increase linearly from 0 to 2Nm in a 90 degrees rotation.
thank you in advance.
    Hello @agiakos, what robot model do you have? Do you have a Robotiq Force Torque Sensor installed?
  • agiakosagiakos Posts: 15 Apprentice
    I have the UR10 and the FTS300 installed
  • David_GariepyDavid_Gariepy Beta Tester Beetle, Wrist Camera URCap 1.3.0, Vacuum Beta tester Posts: 183 Handy
    @agiakos
    I'm not sure but I would try something like this:
    Check initial position and initiate a 1 degree rotation
    Then in a thread:
    Compare with current position to get the rotation variation.
    Based on your example I would then take this variation and divide it by 45 (90 degree/45=2NM) and assign it to a "required_torque" variable
    If the current torque is below the required_torque, then rotate 1 degree.
    Hope that help
    David Gariépy
