matthewd92matthewd92 Posts: 826Founding Pro, Tactile Sensor Beta Testers Handy
edited May 2017 in Programming
I thought that we might want a single thread where everyone can post up any handy little helper functions that they have developed over time that make programming and using the UR robots easier.  If you have any functions that you are willing to share please post the code below along with an example of how to use the code.  If you have any questions about how to use something please feel free to reach out to the author or post a question on here so that everyone can learn from each other.
  • JoseJose Posts: 11 Apprentice
    where I can find the list of commands like "set speed" , "popup" ... ?
  • matthewd92matthewd92 Posts: 826Founding Pro, Tactile Sensor Beta Testers Handy
    The dashboard server commands can be found in this document https://www.universal-robots.com/how-tos-and-faqs/how-to/ur-how-tos/dashboard-server-port-29999-15690/
    the other commands thay that I use regularly are sprinkled throughout the UR support website.
    Thanks for your reply.
  • klacourtklacourt Posts: 12 Apprentice
    It appears the close popup command does not work for the "Protective Stop" popup?  I am running 3.5.3.10825 with no luck...
    AHH!  Just found "unlock protective stop" is a dashboard command!  My reference must have been old.
    Hi, I am controlling UR5 using PC and sometimes results in an error getinverse(): unable to find solution displayed on UR teach pendant. How can I read popup message from pc and then close the popup.
