TheoSaifyTheoSaify Wrist Camera URCap 1.3.0 Posts: 13 Apprentice
edited June 2018 in Programming
 i taught the robot to detect an object, and i saved the  movement toward the object.
When i try the program the robot won't make the registered movement. He started moving in wrong directions after i change the position of the object  from the teached position
  • David_GariepyDavid_Gariepy Beta Tester Beetle, Wrist Camera URCap 1.3.0, Vacuum Beta tester Posts: 183 Handy
    Hi @TheoSaify
    Did you used a moveL and set the snapshot variable used in the cam locate as the feature?
    David Gariépy
  • TheoSaifyTheoSaify Wrist Camera URCap 1.3.0 Posts: 13 Apprentice
    Hello, yes i chose the snapshot variable used.
    But what should i choose for the TCP ?
    @TheoSaify
    You can use your correctly set tcp. If it still not working, please try to reteach the positions, and redefine the position of the object in the camera locate node.
    David Gariépy
    can you show me how ?
    @TheoSaify,
    This video is from a previous version of the URCap but the process is pretty much the same.
    Let me know if you still have any problem
    David Gariépy
    how can i know that i configured the tcp correctly ?
    What is the tool installed on the robot?  You can enter the distance of the tool from the robot flange.
    Even if you did not enter the TCP correctly, correctly, you should still be able to use the camera and pick objects.
    David Gariépy
