nitro13derricknitro13derrick Posts: 1 Recruit
edited June 2018 in Troubleshooting
We are doing the step by step procedure on the training manual using SICK Vision Camera. When we are doing some programming of UR, we found out that the "EtherNet/IP Adapter" is running but the indication is yellow which means that no scanner is connected to robot but on the SICK Inspector tab it is already connected and we can find the object on the live view.
    Unless you have a plc in the system, turn off ethernet/IP . You don't need it for the camera.
