vpeyton
Posts: 2 Recruit
How can you recalculate a feature plane by teaching three points in a program? |
/ Most recent by matthewd92
4 comments |
Has anyone found a way to update/recalculate the whole feature plane including rotations in X,Y&Z? Do you know the math on how the original feature plane is calculated based off of the three points?
Currently I am using feature planes for all of my positions inside of our CNC machines for picking and placing parts in and out of hydraulic vises. This has been working well but now we are moving the robots around more frequently from one machine to another. So now I need a more efficient way to reset the three positions in my feature plane. The big issue I have is most of my programs have their own installation program. This means that I have to teach every recipes feature plane when I move the robot around, usually 3 or 4 programs.
If someone else has it that’d be great. Please post it.
Robotic Technician
Tonnard Mfg.
@matthewd92 Have you found a way to do it?
I am currently stuck in the maths to do this as well. I can get a normal vector to the plane, but then again: I get stuck on calculating the rotation (rpy/rotvec).. It should be as simple as with ABB, but for some reason it's not possible '^^
I was able to find the post where I saw the code for the new plane feature, its actually a script file UR generated with a lot of helper functions in it, one of them is get_feature_plane(p1, p2, p3) you would simply need to assign the return value of this to your feature variable and pass in the 3 points that you want to use. I have attached the file from UR. I know of one typo that existed in the file and so I corrected that, I have not personally ran any of these functions so I cannot vouch for their correctness or completeness.
