Home› Integration
David_Gariepy
Beta Tester Beetle, Wrist Camera URCap 1.3.0, Vacuum Beta tester Posts: 189 Handy
Detect sudden force drops with the new Click Detection Skill |
/ Most recent by Peter_Moore
in Integration
4 comments |
Hello Pros,
Robotiq just launched a new Skill on skills.robotiq.com.
The Click Detection Skill uses the data measured by the FT 300 Force Torque Sensor to detect sudden force drops in a specific direction, in contexts such as the push of a button or the linking of different types of mating connectors.
The Click Detection node will execute a linear motion according to the selected direction and speed, and will consequently result in a successful or a failed detection.
Regards,
- A sudden drop of force greater than the selected Detection threshold results in a successful detection.
- If the force applied reaches the Maximum force value set by the user, or if the linear motion reaches the Maximum distance set by the user, the detection will have failed.
Regards,
David Gariépy
Vicosystems S.L.L.
It is currently not possible to do so with this skill. This is something we could implement though. Are you looking at using this kind of feature in an application you are currently working on? What is your timeframe?
e: [email protected]
w: vanguard-robotics.com
You could try eccentric rotation.
or for example if you were to tighten a screw with an allen key, force could be measured along the X axis.
