Home Integration
2
  • thewavethewave Posts: 6 Apprentice
    edited January 2018
    BLAH! After looking at my post I saw the problem.
    20/01/2018 08:27:10 *** unrecognized option(s) ***
    20/01/2018 08:27:10 	[1]  -nofixes
    Should have been -noxfixes not -nofixes
    Well hopefully my file contents and log file will help someone in the future.
    Thanks.
  • PierreOlivier_ProulxPierreOlivier_Proulx Beta Tester VIsion 1.1 Program, Vacuum Beta tester Posts: 69 Handy
    if you put the export DISPLAY above the x11vnc command, does it works?
    Pierre-Olivier Proulx
    Software Designer
    Its working now. It was my -nofixes option typo in the xsessions file.
  • mkardasinskimkardasinski Posts: 41 Handy
    edited January 2018
    There has been mention of backing up the flash/usb drive before making any changes. What is the preferred method to do this as well as validating the backup?
  • jlespinosajlespinosa Posts: 5 Apprentice
    Hello, I followed up the procedure, and I got connection by VNC Viewer, but after a while without sending keys or moving the mouse the connection is refused from CB3 controller (1 or 2 minutes) .I must to reboot again but it's happening the same problem, any idea ? something wrong at the x11vnc parameters? or something at Debian ipconfig ? because the connection by ftp with Filezilla is refused too
    Please , see attached file x11vnc.log and screeshots
    Thanks in advance
  • mchangalamchangala Posts: 6 Apprentice
    What happens when you SSH into it?
    I don't know to use SSH, I followed the procedure, How I use SSH?
    Use Putty(if on windows), select SSH, put your IP address in, when you click on open, the SSH window will ask for a user name and password.
    Username: root
    Password: easybot
    You will be in your linux backend.  !!! BE CAREFUL AS YOUR THE ROOT USER !!!  You can do alot once your in however you need to know about linux OS and how to navigate with a terminal. I wouldn't experiment in the UR box, better to get a junk computer with Linux and test your changes.
    I think UR has a modify Debian  Linux build.
    To learn about linux you will need to google.  I like Ubuntu and Mint Linux. Or use a debian build.
    Good Luck!
    Ok, I got Putty, and I get now access to the terminal at UR , I like tu access to Polyscope by Tightvnc or VNC Viewer
    I do not know why your VNC and FTP cuts out.  Seems like the system goes to sleep or something. I would read the documentation on x11vnc, http://www.karlrunge.com/x11vnc/.  I would look at the http://www.karlrunge.com/x11vnc/x11vnc_opts.html#opt-forever, which gives insite to the options when you called x11vnc.  You can try to reopen x11vnc onces you SSH into your box.
  • woodchopwoodchop Posts: 2 Recruit
    If you close the VNC viewer, it will not reconnect without rebooting Polyscope.
  • David_GariepyDavid_Gariepy Beta Tester Beetle, Wrist Camera URCap 1.3.0, Vacuum Beta tester Posts: 190 Handy
    You can have a permanent access if you do the following :
    1. In the SSH session, enter the following command: x11vnc -storepasswd easybot /etc/x11vnc.pass
    2. Using filezilla, copy the xsession file from root folder on your computer
    3. Open the xsession file using notepad++ and include the following line at the beginning of the file right under #!/bin/bash:    /usr/bin/x11vnc -xkb -noxrecord -noxfixes -ultrafilexfer -noxdamage -display :0 -rfbauth /etc/x11vnc.pass -rfbport 5900 -forever -auth root -bg -o /var/log/x11vnc.log
    1. Save the file and use filezilla to return the file in the root folder on the controller.
    2. Reboot controller and DONE!  use ULTRA VNC Viewer to connect to robot
    David Gariépy
    Ohh  . same thing  ,
    Thanks David and the other ones help me, I have no idea about what is happening , after reboot and the connection is made....I can play with Filezilla, Putty or Vnc viewer with no problems , but on Vnc viewer  , if I left a while without interacting whith Polyscope , the connection is refused from robot controller..I will try with another PC
    I have packaged an urmagic file for easy installation. Just extract to usb to install the magic file. This is modified from another person.
    I'm curious about how you are using vnc. Do you use it to monitor your production? Do you use it to program your robot remotely? Do you use it on your local network or over the internet?
    At Robotiq, developers use it mainly to test the urcaps we are working on without leaving our seat. I know, this is lazy.
    Software Designer
    Hi, we basically use it for remote programming and remote debugging. As you know it will be tiring to hold the teach pendant and program for a long and complex sequence. Using VNC means, we can use the real keyboard and mouse.
    Hi guys,
    Great news! No need to fiddle with the console and bash code to remotely control your robot anymore. With Remote Access, you can access the teach pendant directly in your web browser. On top of that, you can plug in webcams in the controller and see your robotic cell while jogging the robot.
    Try it out on the demo robot here.
    Software Designer
  • MarkusMarkus Posts: 1 Recruit
    yuvarajoo said:
    Do you know something about the warranty of Universal Robots when "third party" software is gonna be installed?
    Best regards.
  • JstewartJstewart Posts: 62 Apprentice
    Does anyone know if this still works? its telling me that the ftp.dk.debian.org files arent found
    edited July 2019
    It does not work anymore. That is because wheezy is not longer supported by the debian community. You can download the magic file attached and insert it in the controller. Full disclosure: This file comes from the UR+ forum.
    The fact that ur runs on an obsolete operating system is disturbing. It means that the robot is no longer covered by security patches.
    Software Designer
    Where is the file attached at?
    I linked it. The attachment did not work.
    Software Designer
    What do i do after install?
    You connect to the vnc server with a vnc client. The port is 5900. You will have to enter the robot password which is easybot by default.
    Software Designer
    And im assuming that the vnc server would be my ur ip?
    right
    Software Designer
    its not letting me connect.
    Have you inserted the usb flash drive in the controller? Are you sure you are on the same subnet as the robot. Did you enter the pass word?
    Software Designer
    Yes to all. its not giving me an option to enter a password
