David_Gariepy
Hi @Colin
In section
6.1.2 and 6.1.2.2 of the manual, you'll find all the information you need to create your own fingertips.
Be sure to respect the following:
Custom fingertip designs must abide by the following :
  • Fingertip must not exceed 100 mm in height from the fingertip's base.
  • Fingertip must not exceed 100 mm in width from the fingertip's base (refer to Y axis from Figure 6.2.2).
  • Refer to Section 6.2 to evaluate the grip force according to your fingertip design.
  • Applied forces to the gripper must not exceed moment and force limits detailed in Section 6.2.2.
