Home › Programming
T800_412
Posts: 51 Apprentice
Installation or Feature XYZ orientation |
/ Most recent by matthewd92
14 comments |
What is the proper way to setup a plane feature for a UR robot, and then use it in the program for controlling XYZ position of the TCP? I have a UR10 robot with a "pallet"positioned nearby. The robot base is rotated approximately 45 degrees from the XY orientation of the pallet.
I set a plane feature for the pallet, but the Z seems inverted. (when I look at it in on the Move tab and set the view to the pallet feature, the robot is upside down, and up/down for the TCP is inverted. Also, if I try to to move the robot to the position, it tries to invert the tool.
I am setting the points for the feature by placing the TCP (pointing straight down) at three separate corners of the pallet and saving each. (I am guessing this is incorrect?)
T800_412 Posts: 51 Apprentice
Another local distributor helped me to get this working correctly. The solution is to create the feature with the TCP Y axis inverted by entering 3.1416 in the TCP configuration. In this case, the pallet feature is a flat plane parallel to the ground The TCP was set with a tool pointing straight down and the X/Y arrows on the FT300 oriented as desired.
After teaching the feature, remove the 3.1416 from the TCP configuration and then program the robot with moveL commands with the feature selected as the reference. The pose_add command can now be used to move the TCP from the starting point (point one of the feature) with X,Y,orZ offsets.
Referencing 1,2,3,4, how do I setup a feature that will orient X,Y,Z as described, so that when selected as the Feature on the Move tab, the robot image does not go inverted, or when used in the program with a moveL command, the TCP does not try to invert?
The UR10 User Manual seems to describe setting up features as an easy way to make the robot be able to move in reference to something other than the robot base, but I am thoroughly confused by reading it several times and attempting several different methods to teach the feature. I was even told by a distributor of UR to just invert the TCP when teaching it and that will work, which is not true at all.
If you create a feature that, with respect to your drawing view, have X form left to right and Y from up to down, then your Z direction will be the reverse of the base feature. That's because you can only build cartesian feature. If you want a Z in the same direction as the base feature, you'll have to inverse your X or your Y direction.
whats happening when you use the feature in the movel as the reference plane is the system is doing a pose_trans() behind the scenes which is converting your tcp frame into your new feature relative to the base, since the z axis points 180 degrees to the base frame it’s inverting your tool orientation.
This solution works well because you're not offsetting on Z, rx or rz.
In fact, you've created a feature with the Z going down and not up as you want (the right hand rule as @matthew92 said), but pose_add use a position corresponding to the base frame but an orientation referred to the tool frame as mentioned here.
The most important is that you've find a way to solve your problem.
which one is the most effctive way of programming for a palletising application, considering speed and motion optimisation
when we want to have multiple TCPs and subprograms for each pallet points
We will do things like set up lists for the number of rows and columns, the angle that the particular box is at for each position, if one layer is different than the next we can handle it this way. We have done it a few different ways with the arrays but they all function pretty much the same, figure out where you are on the pallet and then query the system (the index in the list or lists) for what to do at that location and then perform a calculated move at that new position.
Hope that was helpful.
lets say i have a tray containing 64 components, then do i need to define all 64 of them before start of the program using an if statement.
i want make use of the feature plan to adapt to the location changes.
plz share a snippet if possible to understand how you are creating a custom function.
THANKS IN ADVANCE
If the wheel size or array on the pallet is changed, I do not have to reprogram, just have the operator enter the new OD, and array size XYZ (wheels left/right, wheels front/back, number of layers)
so maybe we do something like this (pseudocode): Assuming we have taught a feature plane called myPallet
You may need to account for how the plane was taught and use a rotation in either the X or Y to flip the orientation of the TCP, this would cause the first calculation to look something like this assuming a flip in the Y axis
thank you for your help, its a nice way of programming
