SarbdeepSarbdeep ApprenticePosts: 11 Apprentice
edited October 2017 in Robotiq Products
Dear Team, Can 3finger gripper perform weighing where it need to pick-up the product and weigh simultaneously ?
  • SarbdeepSarbdeep Apprentice Posts: 11 Apprentice
    Thanks. so do you mean robo can pick-up the product and do the eighteenth of same simultaneously after FTS is installed.
    @Sarbdeep The easiest way to do this would be to add a separate force sensor to the system such as the Robotiq FTS.
  • Brittaney541Brittaney541 Apprentice Posts: 34 Apprentice
    Can you find the weight with the Force sensor that is already in the UR5e?
  • mhowemhowe Handy Posts: 41Partner, Wrist Camera URCap 1.3.0 Handy
    Yes you can, measure the FZ and depending on the weight of the item you will have adjust your Newton range. Just make sure you zero out before you lift.
