Driver not able to install ... keep getting an error, see the video attached
    Accepted Answer
    Hi ,
    I figured out what went wrong.
    After I unzip the files, I usually delete the folder containing the CB2 programs because it is a CB3 controller that I am using.
    Usually the driver installation is successful on the older versions, but if you delete the CB2 folder on 1.0.8 or 1.0.9, the installation will result in errors.
    Hope this helps!
    Hi there,
    The video is not working and it's very hard to hear you on the phone.
    Anyway, I check the possible message we can get, and yours would be linked to either :
    Package is not unzipped
    Installation files are not in their original state, you may have moved them incorrectly
    Can you clear your USB stick and unzip the package on your USB stick root again ?
    Hi there,
    I'll take note of that and add it to UR install course ! thanks!
