AZalmanovAZalmanov Posts: 19 Apprentice
I believe the issue I'm experiencing is called a singularity. I set my waypoint using a pose that keeps the joints fairly far from their limits. Sometimes when I run the program it moves the way it was programed and other times the robot will collide with itself by taking a different pose to reach the same waypoint. Is there a way to mitigate this. I've tried both move l and move j and a combination of both, I have also tried adding more waypoints. Thank you all in advance.
  • David_GariepyDavid_Gariepy Posts: 175Beta Tester Beetle, Wrist Camera URCap 1.3.0, Vacuum Beta tester Handy
    Hello @AZalmanov,
    Could you send us a video so we have a better understanding of what is happening?  You said you have the same problem when using moveJ?
    David Gariépy
  • Michael_PerezMichael_Perez Posts: 9Beta Tester Camera URCap 1.2.0-beta Apprentice
    Hi @AZalmanov ,
    Here a quick tip.
    You need to avoid the singularity points on the UR.
    Also, everytime you change the position of the robot use a MoveJ.
    What kind of alarms you are having with your program?
    Michael Perez
    Engineering Manager
    Campbell & George Co.
    A division of Buchanan Automation Inc.
    I added a few more waypoints and used blend radiuses. Everything is working except I get strange jerks if my speed is too fast. Still need to tweak a little. I have been trying to upload to YouTube all morning but I believe our app control doesn't allow it.
  • armormodellerarmormodeller Posts: 14 Apprentice
    Yeah I got a program that has the jerking in it as well. Best thing we did was slow the joint speed down a bit and the overall speed we reduced 10%. Try that.
    Also try to have less acceleration
    Michael Perez
    Engineering Manager
