PierreOlivier_ProulxPierreOlivier_Proulx Beta Tester VIsion 1.1 Program, Vacuum Beta tester Posts: 68 Handy
Does someone knows if it is possible to trigger an e-stop, p-stop, safeguard from the UR simulator?
Thanks.
Pierre-Olivier Proulx
Software Designer
  • matthewd92matthewd92 Founding Pro, Tactile Sensor Beta Testers Posts: 1,084 Handy
    I've triggered protective stops by using two waypoints that have a blend on the first waypoint and then a wait command in between the two waypoints. That throws the set point error and stops the simulator. I've tried making outrageous moves, like through the base, before but they're not very reliable for triggering protective stops.
    Thanks Matt.
    Software Designer
    protective_stop()
    Software Designer
