MRWinterMRWinter Posts: 2 Recruit
edited July 2017 in Robotiq Products
Good day ladies and gentlemen,
we are a group of students and need some help.
We are looking for a gripper which can handle a circuit board leaving us only 6 mm handling space on the circuit board itself.
The customer wants to use a Universal Robot UR10. The industry often uses pneumatics for handling a circuit board but in our case it is impossible because the boards are transported and stored in a sort of tower tray with its own chassis. About 10 mm space from housing to the first circuit board or from board to board.
Circuit board data:
dimensions: 250 mm x 200 mm x 4 mm
weight: 300 g
Do you have any ideas or gripper solutions for us?
BR
D.Winter
    Could you simply use 3mm thick fingertips? This would give you a 3mm stroke opening to release the PCB.
    Our gripper allow to precisely open to a given position. You'll be able to open the gripper just enough to release the part.
    Best regards
    David Gariépy
  • MRWinterMRWinter Posts: 2 Recruit
    Dear Mr. David_Gariepy,
    thank you for your answer. Sure we could use a 3 mm thick fingertip if it can put enough pressure on the pcb in order to handle them?
    Can you relate to specific products?
    Thank you sir!
    Mr. Winter,
    Here is a link to the product page
    Here is a link to the product manual
    You can find informations about the grip force in the section 6.2 of the manual
    David Gariépy
