wileydavis
Posts: 11 Apprentice
Force Touch-Off Giving False positives |
/ Most recent by wileydavis
5 comments |
I'm probing a pallet of stock to find the top piece using the force() function. It works really well but occasionally gives false positives where it thinks it's hit something when it hasn't. If I use the force() < 60 then it only happens once every 100 parts or so. But I've found that it becomes more unreliable as the force limit goes down, where at 30N it always triggers right away. I have the payload set using the weight and cg given by robotiq (900g). Here's the code I'm using:
Tray Probe Probe Variables Wait is_steady()≟ True pocket_bottom≔pose_trans(Tool,p[0,0,.127,0,0,0]) pocket_top≔get_actual_tcp_pose() If force()<60 MoveL pocket_bottom pocket_empty≔ True empty_pockets≔empty_pockets+1 pocket_top If empty_pockets≟10 PatternPoint_1 Gripper Open power_down()At 30N it happens at the beginning of the move. But at 60N, on the occasions it messes up, it happens at the bottom of the pocket. Is it possible that the stop at the pocket_bottom waypoint causes the loop to exit before setting pocket_empty to true? Maybe slow it down? I'm probing at .025m/sec.
wileydavis Posts: 11 Apprentice
@matthewd92 the units are in/sec and in/sec/sec. over four runs the averages are all within 2% of one another for a given speed/acceleration combo.
The reason I ask this is generally I will have something like this
The reason I break out the rest of the moves beyond the actual probe move is I only want to exit that portion of the if statement once I find something is so that I know for certain if that flag is raised or lowered so that I can take action on it and guarantee that the action will take place. If you have the check box checked on the if statement, as soon as that condition is no longer met the if statement exits, which is the behavior that we want. If you do not have the checkbox checked then you are basically entering the statement if the condition is met but then the only thing that causes it to exit is the completion of the block, not the changing of the condition.
Also, I have seen this same issue, the built in force sensing is not the most robust feature probably due to how its implemented. We wind up using forces around 100 to 120 for a lot of probing tasks, I will generally start high and then work my way down to where I find a good balance between probing effectiveness and not pushing too hard on what we are looking for.
24.36 average force with a high of 46 @ .5 / .5
16.45 average force with high of 36 @ 9.8 / 47.2
12.43 average force with high of 26.02 @ .5 / 47.2
So the force values vary a good bit but slowing the tool down but keeping acceleration up seems to stabilize them somewhat.
