jmagdaleno
Posts: 3 Apprentice
How to obtain the current time |
/ Most recent by matthewd92
7 comments |
Hello everyone.
I'm trying to measure the cycle time of a process using a UR10.
My idea was to get the time at the start and at the end of the process and calculate the elapsed time with it.
The problem is that it seems there is no function that returns the time ( or at least I couldn't find it in the script documentation ). I was trying to overcome this problem connecting to the real time interface and read the timestamp from there, but then again, there is not a function to read binary floats.
Any ideas on how to get the time?
We want to be able to do it only with the robot. We want to avoid using an external computer to ask for the time.
Simply measuring the time with a clock is not acceptable as it is needed to obtain precision values.
matthewd92 Founding Pro, Tactile Sensor Beta Testers Posts: 1,184 Handy
There is not a time function on the robot. Here's how you to it though. Place a thread in the program and in that thread you place the following.</code>time=time+.008 sync()</pre>The sync command takes up a time slice of robot time which is processing at 125 Hz or 8 milliseconds. <br><br>Then in your program you can get the time at the start of a process and the end by simply referencing this value. we do cycle timers by simply setting time to 0 at. The start of the process and then grabbing the time at the end of the process. I also do similar things for wait timers when I want the robot to wait for instance both a time or an input to happen. An instance of this is wenfite a camera for a feature verification. The camera gives us an OK input if the feature is present but nothing if it's not present so I want to wait for either the output to fire, good part, or a specific time to expire, bad part. So we do something like<br><br><pre class="CodeBlock"><code>I=0 goodPart= False Loop I<3 or digital_input_0 not true I=I+.008 sync() if i<3 goodPart = True <br>
That will cause the program to wait for either the timer to exceed 3 seconds or the input to fire. Once the loop ends if the time is less than 3 seconds then the input must have fired so we have a good part
It seems that is the best way to do this kind of things without having a proper time function in UR.
The downside is that it doesn't deliver very accurate results and it is dependant on the program because the threads management overhead.
In a sample program, with only time calculation and a simple cyclic movement between two points there was a 5 seconds delay in just 2 minutes of execution. In the process that I want to measure the 5 seconds delay was already present at 1 minute of execution.
Anyway, even not perfect, is enough for our case, but if someone else needs really accurate readings should search for another solution. I hope UR will include this kind of function in the future as other robot manufacturers do.
Not sure if this matters but background threads do not start running until the program gets into the actual robot program, if you're hitting start on the watch when you hit play that's not an accurate method of timing. If you have code in the before start section that code must finish executing before the threads start.
If we have instances where we need very precise time we make an xmlrpc call to a server we have attached to all of our robots and return the current epoch time, that gives us a time down to the ms.
Thanks again for the help Matthewd92.
I have used the timer example above and it works well until the operator breaks the light curtain, then the program along with the timer pauses.
You can access the clock or the time the UR has been powered on through RTDE 'timestamp'. IS there any way to use this feature as a variable or is there any other way around this?
The clock seems like such a no-brainer basic feature to allow programmers to reference I'm surprised they make it so difficult (or impossible) to access it.
