mertzgamertzga Posts: 16 Apprentice
I am wanting to have my UR10 stop if a part is not grasped by the 2 finger adaptive gripper. Prior to installing URCaps the program went something like
If rq_obj_detect=0
MoveJ waypoint
Pop up message
Halt
This doesn't seem to work the same way with the URcaps upgrade? How can I accompolish this now?
    @mertzga this will work but you need to correct a few things. The function is " rq_is_object_detected" and it will return either True or False, not 0 or 1.
    Tell me if it works with this.
  • mertzgamertzga Posts: 16 Apprentice
    Sweet, Thanks! I will try that and let you know, :)
    Sadly, when I enter it that way it throws a "compile error" stating, "rq_is_object_detected" is not defined" I put a variable in the before start sequence rq_is_...=False. With the same result. Thoughts?
    Funny you point me to instructions I was just doing that reading. Thanks.  :)
    We use it quite a lot. In case you aren't aware all you need in the if statement is rq_is_object_detected(), you don't have to say equals to True for it to evaluate correctly.
