Tim_Smith
Posts: 38 Apprentice
Can I lock the robot in a specific orientation to do hand's on teaching? |
/ Most recent by matthewd92
4 comments |
Hi Everyone,
I was wondering if it's possible to lock the robot's wrist in a specific plane to teach the waypoints to the robot? I am a big fan of using the UR's Freedrive mode to move the robot from one waypoint to another. But it is difficult to get the tool flat against the table without having to program the angles in the coordinates system.
I wish this was a built-in feature. Like other manufacturers where you can choose which axes you want to unlock to move by hand.
Here is a video showing the different functionalities linked to the ActiveDrive:
P.S. Thanks for mentioning that you can program the robot using the sensor and then removing it to be able to program several robots using the sensor. I had not thought of this! As you said, just remember to adjust the TCP, otherwise you will have a Z offset.
Robotiq Integration Coach
1-418-380-2788, option 3
For us the only reason we aren't using the sensor more comes down to simple economics, as a young, start-up we have not felt that we could spare the purchase cost of the sensor at this time. We do a lot already with calculated waypoints and so there is a lot of our programs where it would not help as we are moving the robot on some calculated path.
I'd be curious to hear from you though if you decide to get one and use it to see how much time you feel it saved you in programming an application as that might help us decide on a path forward ourselves.
