Filling up trays |
/ Most recent by matthewd92
in Applications
3 comments |
I have been testing an application where the robot would pick parts from a table top and insert it in the proper position of a tray. The client does not want to have a jig that would locate the tray each time. The operator would put the tray on the table, turning on a switch saying to the robot that a new tray has been inserted. The robot would then start picking parts from the table (also using vision) and place parts in the tray.
I think there are many ways this application can be programmed and I wanted to share mine to get some thoughts on this. My idea is to use a counter variable that would keep track of the parts ID to be inserted in the tray. So under the camera locate, depending where I am at with this counter variable, the robot will move to a certain location to place the part in the tray. Below is the code programmed for the first two positions in the tray. Note that the first camera locate is to locate the part to be picked and the second is the one to locate the tray.
I find that this setup works fine but is a bit time consuming to program if you have a large tray. Any way we can use the Pallet Tool under the vision locate? Any other way you would go around to program this?
BeforeStart tray_count≔0 Robot Program MoveL Waypoint_4 Waypoint_1 Camera Locate Gripper Move 54% obj_found≔ True MoveL Waypoint_2 Waypoint_3 Gripper Close Waypoint_2 If tray_count≟0 MoveL Waypoint_5 traydropsnap_var Camera Locate If tray_count≟0 MoveL Waypoint_6 Waypoint_7 Gripper Open Waypoint_6 tray_count≔1 ElseIf tray_count≟1 MoveL Waypoint_10 Waypoint_11 Gripper Open Waypoint_10
To keep from having to program each individual way point you will need to set the number of rows, columns, the row spacing and the column spacing, you can then dynamically move to each location as you are filling the tray.
this is really nice! Thanks for the tip!
In case it wasn't obvious, the PalletCorner point is a taught feature. You could make this point variable if for instance you are using a camera to find the corner of the pallet if it were randomly placed, then the pattern would change relative to the pallet
