Home› Applications
Sebastien
Posts: 219 Handy
Why and when would you consider adding a PLC to a UR Application |
/ Most recent by matthewd92
in Applications
3 comments |
Every applications so far that we programmed did not require us to use a PLC. We had enough process power in the UR and all the IO's that we needed. I saw many post on DoF referring to PLC. What are you criteria when you decide whether or not you need a PLC. This adds cost to the projects and we simply don't want to buy it when we don't need it.
thanks a lot and that makes sense since the IOs are quite limited on the UR. Anyone else using really a PLC to control the robotic cell and probably having the robot as a slave in the cell?
Back to the original question, I have seen an AB PLC used with the robot because the equipment that we were integrating into was ran by the AB and was an existing line that we added a robot to when I was still at SFEG. This was before UR added the Ethernet IP or prominent so it was basically a input/output handshake between the robot and the machinery. Similar to how we wire into older Haas mills.
