SebastienSebastien Posts: 194 Handy
Hi pros,
we haven't search much yet into that topic and my first was to ask you guys if you done something like this. We are currently looking at a project where the UR would need to be moved on a rail. So far it is quite easy as the rail will have only two positions (one at each end). So the integration is quite simple.
However I was curious to see how hard would it be to have the UR move on a servo driven axis? We are used to work with this on Fanuc robot where the axis is integrated to the system such that when you move a 6 axis robot on a rail, on the teach pendant there are 7 axis to move. So when you teach points, they record all 7 axis values. I am guessing that it would be feasible to make this work on UR but could be tricky. What do you think? Any experience you are willing to share?
  • matthewd92matthewd92 Posts: 384Founding Pro, Tactile Sensor Beta Testers Handy
    @Sebastien do you need to be moving the robot while you're moving the slide or is it move to one end and do some work then move to the other end and do some work there? We've looked at a couple of applications that needed a slide as well and have done a little noodling around how to make it work.
    I do wish that UR would allow for 7th axis control like other robots.
  • SebastienSebastien Posts: 194 Handy
    @matthewd92
    Moving the robot to a certain position, do some work there and then move the rail to another position is something that could work in our case and I think is feasible to do with UR. However we would be interested to see if anyone tried a sort of coordinate motion between the rail and robot to have both move at the same time!
    We have toyed around with the idea but we have some advantage on that we have a seperate computer attached to each of our robots to enable something like that.  To accomplish that we'd basically be monitoring the robot position in real time, calculating the current distance from the final point and then moving the linear slide in relation to that distance to get the accel and velocity required for the slide.
    We do have a robot running a 7th axis but it's not moving the robot, it's moving the part for the robot and there is some coordination between those two but it's limited in scope.
  • MikeWalkerMikeWalker Posts: 1Partner
    I guess you could use the conveyor function  ( you could effectively treat the conveyor function as your 7th axis) read in from a linear encoder or simply read the encoder pulses between the start and finish points programming your bot and io accordingly to respond when encoder reaches the required pulses which I assume would be the opposite end of your linear rail.
    Festo had a UR5 on a linear slide at Advanced Manufacturing Expo, not sure exactly what they were doing with it just saw a tweet from UR yesterday about it
  • Tyler_BerrymanTyler_Berryman Posts: 101 Handy
    I saw that Numatic Engineering worked on a solution incorporating a UR robot on a linear actuator (Rollon Corp).
    @baghakian Could you share how you integrated the control of the robot with the linear actuator on this project?
  • baghakianbaghakian Posts: 3 Apprentice
    Since the UR does not have pulse output, we need to rely on discrete outputs to run the servo.  The Yaskawa servo motor that I used was controlled by the "indexer" style controller.  Multiple points are pre taught in the servo controller and through a binary discrete inputs, you can select which position to go to.
    Please remember that this will not be a true 7th axis.  I had the robot moving while the linear actuator was moving (used a thread in the UR program).
  • carrondocarrondo Posts: 4Partner Apprentice
    Hi @Sebastien,
    For a very straight forward solution without the need to do interpolated motion with the UR, we highly recommend IAI electric actuators - https://www.intelligentactuator.com. We already have several applications using them together with UR3 and UR10 with no issues.
    Strong points of IAI is a very extensive range and easy setup. You can "talk" with IAI by digital I/O or serial communication.
    If you want, we can suggest a model based in your requirements such as effective stroke, necessary speed, etc..
    @carrondo would it be possible to get some ballpark prices for lets say a 1 meter and a 2 meter slide that can move at 1000 mm/sec?  We have looked at a number of potential applications that would require a system such as this.
    Hi @matthewd92, IAI has more than 700.000 models so pricing is really a tailor-made subject.
    But a worst case scenario would be a 2m slider for a UR10 together with a controller it will come about 5k€ (one ballscrew unit, repeatability ±0,01mm, 1.080mm/s, 45kg payload with 0,4G acc/dcl).
    After finished all the electrical connections, the unit will be ready to run in less than 10 minutes.
    We also used them when we have a robot with dual grippers and the application needs the distance between grippers to be variable.
