bsawlorbsawlor Posts: 23Partner Apprentice
As indicated on the spec part, the camera can have up to 5 mp
MAXIMAL RESOLUTION 5 Mpx @ 2fps (2560 X 1920)
That selection has to be made in the settings for the camera.  Is that done by changing the resolution to one of the 3 available?  The 2560x1920 didn't appear on the version I had installed.
  • Etienne_SamsonEtienne_Samson Posts: 356 Handy
    @bsawlor that setting is what the camera could provide but we are not using that with the Camera Locate URCaps and you cannot change it. That application uses 640 x 480 at 30 FPS. We use that setting since we need the FPS and not the resolution for our object location applications.
    We had that spec during the initial beta release back in June because we were not fixed yet on that, I guess we should update the specs and make it clear what we use for the Camera Locate software.
    On the other side, what do you need that resolution for ? Was is it just to do some test?
    Technical Support Manager - Responsable soutien technique
    +01 418-380-2788 ext. 207
    esamson@robotiq.com
  • bsawlorbsawlor Posts: 23Partner Apprentice
    I did a demo yesterday and the customer was specifically referencing that resolution in some things they were looking at vision for.  Based on what they want to do though, I think a standard vision system would be better suited.  They're looking for 1mm accuracy.
