@NickBaron1 you can do so using script functions we provide. You should start by having a variable to record the gripper position. Use a variable assignment with:
position= rq_current_pos()this will give you a number between 0 and 255 that represents your object size. With the 2F 140 you get an approximate resolution of 0.65mm. Note that you will need a minimum thickness of 1.2 mm to have something reliable on object detect.Hope that helps.
I'm looking to measure the width of objects using the 2-finger 140 gripper. Is this possible to do and if so how do you do it?
Thank you,
Nick Baron
